jhwbigley
any ideas how much this is going to cost us?
now to bed
John-Henry
now to bed
John-Henry
Argee":9njeuprb said:The board will need cutting out and replacing, obviously, so that's a case of finding the board edges (unless you're unlucky enough to have damaged two boards), cut it out, remove fixings (nails or screws), replace with new board(s), tape the joints, skim and decorate. The only variables I can think of are if it's one or two boards, otherwise you should get very similar quotes.
You may have to allow for removing and replacing the skirting board, BTW. No doubt you could do the removing yourself, which would save a little bit. If you can replace the board(s), so much the better, but whatever you do leave the taping, skimming, etc. to a professional.
Good plasterers are always busy, so if you can prep the job, it would probably get done "on the way home." The best plasterers, IME, come recommended from friends.
Ray
matt":bpteube7 said:You could knock out the loose bits and then adhere a slightly larger piece of plasterboard to the back of what remains before plastering back up to the original thickness. The trickiest part is getting the slightly larger bit in the wall. You'll have to make it either longer or wider but not both and can only tell the best way to go once you got the old stuff out of the way.
The other option is mesh to plaster on.
pren":2fabwyc2 said:Job done. :wink: :lol:
