woodbloke
Some years ago I saw maker producing a table for Linley. The top was the ususal 18mm mdf and it was going to be lipped before veneering. Having made the top, he then set about producing a set of template(s) to bearing cut the lippings, by using only a router, guide bushes and cutters to produce a perfect match. But how?
The process was very convoluted and involved changing bushes and cutters at least a dozen times before the final set was ahceived. The problem is that whilst one side of a router cut to a given radius will produce the desired curve, the farther curve will be a larger radius (by the dia of the cutter), which will not make a perfect fit when offered up. If a circular table is being produced, this is no big deal as you can simply adjust the radius of the router jig to the correct distance for the lipping...trouble is, this table was elliptical. I have been pondering on this one for ages,so....... can anyone work out the sequence of bushes and cutters to produce the template(s)? - Rob
