Mark S
Hi, first post here apologies if asking for help is poor etiquette or this is the wrong sub-forum.
I've just started my first 'proper' wood work project - building a desk for a home office. Nothing fancy just a table top and square metal tubing in a rectangle shape for support.
I managed to find an old used school worktop at a second hand/recycling place in Devon that is perfect. I was told it was African Mahogany and my father-in-law reckons it might be Sapele - I am not sure at all. It is a dark hardwood with a good weight, colour and grain made out of two pieces joined together.
The piece was a good 2.8m long by 600mm and about roughly 3cm (inch) thick. I've cut it down to 1.8m for the desk with the spare metre for maybe some shelves to match (haven't decided yet).
As it was an old school worktop it has lots of sign of abuse and use - some of which gives it the character I like. However it has some glue residue along one edge and paint near the edge on the bottom. This picture is of the top before I've done anything apart from cut the piece down (note the glue edge):
End grain:
Close up of grain:
I decided best course of action would be to sand down the entire piece to remove the glue and residue from the edge and also remove all the little nicks, knocks and try to smooth the piece and remove anything that might have soaked into the wood - I don't think it ever had a varnish or protective coat on it. I work with a random orbit sander first as hand sanding the glue was taking an age. I then finished with increasing finer grit up to 120 and then 240 (got carried away and love the feel of the wood).
I finished the edges and rounded the corners. I cleaned the surface with a hoover and brush, then used a tack cloth to get rid of any dust. I used white spirit to clean and get an idea of what the wood would like when varnished.
I didn't want to change the colour too much, really just wanted to protect the wood from water, drink spills that sort of thing so thought a clear satin varnish would be OK. (Ideally I want a protective coat that didn't change the colour as much as the varnish did).
I applied a coat (probably a little thick if I'm honest) and the piece darken (as expected) but not uniformly, more on that in a bit.
Below is a picture comparing the varnished coat after drying with a raw wood from the off cut:
You can see from that picture some patchy-ness of the varnish on the wood. Below are better pictures of my problem:
As you can see the varnish isn't consistent, I've tried googling but my inexperience isn't helping. It's not the same along the grain, so one part soaks up and then as you can see the next bit hasn't and is much lighter. I actually quite like the dark look but the light patches are ruining the finish for me.
Maybe I didn't sand enough? It felt the same smoothness all over and I couldn't see anything wrong before.
Maybe the white spirit haven't all evaporated? It looked dry, maybe the white spirit stopped the wood absorbing in certain places.
Maybe oil or grease left in the wood? The wood was even coloured after sanding without any obvious differences that I can now see with the varnish.
So I've decided that I don't like the coat and so have started sanding it back to raw wood:
It is coming off OK so I should be able to get back to the same start point.
What I am looking for is advice on why this happened, ways to avoid it once I'm ready to go again and any other advice.
(and if anyone knows what wood that would be great too!)
Sorry for the long post for a first timer, thought lots of pictures and detail would make it somewhat interesting!
Thanks,
Mark
Thanks,
Mark
