Mike,
I have not used Rustins Danish oil but Liberon finishing oil. I understand that they are both based on Tung oil and are quite similar.
This is how I use the finnish oil, apply a coat I use a brush but you can use a rag if you like.
Wait 10 minutes, then with a clean rag, wipe off the excess oil. For big jobs you need a supply of rags and be careful with the used ones. They can self ignite, spread them to dry before chucking them in the bin. :shock:
Leave the oil to dry, Liberon recommend 5 hours and repeat the process.
Cut back before the final coat, which depending on what your doing could be anything from 3 to 7 or 8. Stand back and admire finnish.
