Hi,
This is my first real project. I'm making an oak coffee table from worktop offcuts. I've reached the stage of dry assembling it and am about to start finishing.
My plan was sand starting with 80 grit - trying to do as much as I could before glueing up, and then use higher grit for final sanding. The final finish will be danish oil to match an existing kitchen worktop.
I've read is the forum about sanding sealers and grain fillers - are these necessary and when should they be used?
I also have some tear out on one or two of the staves that I'm not going to be able to plane/sand out - what would be the best way to 'fill' these to give a good finish please?
Thanks, Colin
Thanks, Colin
