fellas
I recently took delivery of a Record BS350. I've been setting it up today as per the instructions and accompanying DVD (Bandsaw Masterclass with Alan Holtham). Try as I may I can't get the darn thing to cut straight. At the start of the cut the blade "wanders" slightly to the right. This happens whilst ripping and cross cutting, all I'm trying to do is cut some tenons in pine, the stock is 3 x 2 so no massive loading causing the problem. I initially thought that blade tension could be the issue , the machine comes with a 10mm blade, I've tried tensioning it up to where the tension gauge says a 16mm blade should be tensioned to but the problem remains (I'm reluctant to go any farther in case I damage something). The thrust bearings and side bearings are set correctly top and bottom and the blade appears to track correctly on the wheel. the blade is also 90 deg to the table and parallel to the rip fence. the blade guard is down as far as the stock will allow.
I'm now at a bit of a loss and am getting quite frustrated, I've been at it for nearly 2 hours. I have Mr maskerys DVD's so will have a look at the one on bandsaws tonight.
I'm now starting to think that the blade may not be of the best quality which may be causing the problem or that i need a different width blade for what I'm trying to accomplish.
Anybody out there have a BS350 who may have experienced similar issues, or indeed anybody able to offer any advice on what i may be doing "not right" (don't like to think of what i'm experiencing is something that I'm doing "wrong")
Many thanks
Vinny
(frustrated of Wiltshire)
Many thanks
Vinny
