I've just bought one of the above bandsaws. It arrived yesterday and I spent a while in the evening assembling it. Tonight I had a go at setting it up. I've never had a bandsaw before, so forgive me if I'm asking stupid questions, but I'm puzzled by the blade guide bearings.
Following the instructions I set the thrust and blade guide bearings according to the specs. The thrust bearings were to be 1 mm back from the blade and the guide bearings were to be 0.5 mm from the side of the blade and 1.5 mm set back from the teeth. I should really say "set as best I could" because they move all over the place when I nip them up. If this is a critical adjustment, then it's going to be fun with these things.
I've read some articles that mention the bearings touching the blade, and some others whereby they are set about the thickness of a sheet of paper away. Now I'm sure my problem is compounded by the fact that I probably don't have the blade correctly tensioned (it's the one that came with the saw, but I also bought an Axcalibur one too) but all these different opinions are confusing.
As I've said I've never had a bandsaw before, so my opinions may be irrelevant but as far as I can tell, it is a well constructed and substantial machine. I feel though that a better job could be made of those bearings, they really are incredibly fiddly, and the table tilt mechanism is fairly crude. Other than that, I feel I have the money's worth. I just wish I had bought the wheel kit as well.
Does anyone here own one of these saws and what way do you set your tension and bearings? I've read that 1/4 inch deflection with the guide raised fully is about right, but while I am unsure whether or not my bearings are correctly adjusted, I haven't tightened it up any further.
On another note, should I bin the blade that it came with and fit the Axcalibur one now?
Thank's,
Michael
Thank's,
Michael
