Need help with electrics
Cameronhill97
24 Jan 2016
Lancashire
Before I start I just want to say I know virtually nothing when it comes to electrics so please bare that in mind
I have a small workshop which when I first got it fitted out I only had bench too machines all with ordinary household plugs, therefore I just have ordinary sockets running down the two long walls of an 20ft container.
I'm looking at upgrading a couple of machines however they require 16 amp plugs, therefore my question is can I adapt the circuit I have now to wire in a 16 amp blue socket or does it mean running whole new lines back to the house?
I know this may be a very broad question but any help would be very welcome
I imagine a 16 amp socket would be supplied by a radial back to the consumer unit in your workshop, with its own circuit breaker.
A bit like a cooker or shower in a house.
Im not an electrician though so could be totally wrong, so dont go by my advise. And the usual, you cant do it yourself needs a qualified sparkie applies.
It all depends on how it was wired up in the first place, do you have a fusebox in the workshop?
You will need to get a Part P certificate for any new work done, so you would have to call a sparky and he should be able to advise you.
You could then do the work and get the sparky to connect up.
