HantsHog
I make small (10x6x9cm) wooden boxes out of 18mm softwood for use as insect hotels. I currently glue and screw them with 6gx1.25" screws which make for a good sturdy build albeit overkill. Each box has 8 screws and I make about 50 at a time.
I'm now looking at speeding up the build process by replacing the screws with hidden nails, pins or brads using a gun but keep the strength of the screws. I would also like to use the same tool for different size of nails if possible.
Happy with electric or air gun with small compressor; gas is probably a bit overkill and pricey. Small workshop so space tight. Price under £100 new or decent second hand brand off eBay.
Also not sure between nail, pins or brads so guidance on that as well please.
