okeydokey
I've been asked to help someone who has a ML8 with an indexing plunger that plunges (smiles) but the pin bit that would engage in the holes in the spindle to lock or position the shaft seems to have broken off and is missing. I have checked and yes the plunger does fully move inwards towards the headstock.
Question how do you remove the broken plunger? could you use a bent at 90 deg pointy/pusher to push/force it out from the headstock would this work? Plus is there some sort of spring and ball bearing that clicks/locks it in position when it is plunged in or pulled out? Any ideas - next Q of couse when its out where I can get a replacement?
thanks in advance to all for reading and help.
