Higon
I've recently got one of these beasts, finally got it hooked up and found there's a nick in the blades. thankfully it came with some spare blades, but not the jig for setting them. (The multico part number is NTH 2025) It's also missing the roller setting gauge (SP1230), other than that it seems to be in really good condition and runs well.
I understand that Multico are no longer around, so a bit of a long shot but does anyone have either of these gauges, or the details of the dimensions for them? (I've searched online and think the blades need to be set 1.4mm above the 90mm drum).
If all else fails then I might well have to dust off some geometry books and work out what the dimensions of the jig should be but its been so long since I did any of that, I'm not sure I'd trust any answer I calculate!!
EDIT;
Having been unable to find a jig, I made one. The drawings are at the bottom of this thread. Non euclidean geometry wasn't required after all, CAD did all the fancy footwork and made it really easy.
EDIT;
