There seem to be hundreds out there, many similar but can't find one that will do everything I want.
I am building a wooden clock, and will probably build more as I'm thoroughly enjoying it.
My main problem is turning and accurately centre drilling some of the smaller parts. Oh and also, as a 79yo pensioner, not a lot of money
The ideal lathe will turn up to about 30mm diameter - preferably the chuck will open to that so I don't have to make spindles to hold the pieces.
Maximum turning length, only about 150mm.
Ideally I need a tail stock that as well as having a rotating centre will also take a small chuck - about 6mm.
I have a mini lathe thing that only has a 6mm chuck capacity! It's driving me nuts having to drill everything and make a spindle for it to get it into the lathe. Once there it works a treat!
