Chris_belgium
- Joined
- 7 May 2006
- Messages
- 272
- Reaction score
- 0
Hello,
as some of you might have noticed I am in the process of building a sliding driveway gate, the gate is made out of hardwood (aphselia doussie), the posts for the gate will be a metal pipe as a core wich will be cladded (correct term?) with aphselia planks on the outside.
https://www.ukworkshop.co.uk/forums/viewtopic.php?t=34019
Question now is how to do this?
This is a previous gate that I made, I just glued the planks to the metal and glued the edge joint between the planks. Offcourse no 2 years later, the planks have moved a bit leaving me with gaps between the planks.
Offcours i want to prevent this this time round.
my ideas:
easiest would be to route a tongue/groove on the planks and don't glue them up but just slide them into each other. I don't really like this look, so only want to do this if there is no other option
second idead, glue up 4 boards, one for each side of the post, glue them to the metal and join them at the corner with the plank sliding into a dado, wich will allow for some movement.
Last idea and the one I prefer, make a square box, a couple of mm oversize than the square metal pile. Weld a small lip on the bottom of the pile and just slide the entire wooden box over the metal pile.
All advice is more than welcome!
piles in question 25 x 25 x 200, 8mm thick.
my ideas:
