Hi folks
I bought a used HC260c and have only gotten around to setting it up. I've watched the videos and was raring to go. I had some difficulty getting it started in both planer and thicknesser mode, so I stripped it down and operated each of the safety switches manually. I was able to get it working. However, the chip extraction cover that triggers the third hidden switch is broken and will never trigger the switch. So I decided to do away with the switches altogether.
Okay, that might not be the best thing in the world to do, but it's my choice. The second silly thing I did was disconnect all the wires in the switch box so that I could fit a basic On/Off NVR switch - the silly part was I didn't photograph how all the wires were initially connected as I didn't expect to need to reconnect it.
So now I have one of these http://www.axminster.co.uk/axminster-li ... nvr-switch
It came with no wiring instructions so I'm a bit lost. I expect I could use the original switch, but bypass the selector barrel.
Would anyone be able to assist me in wiring either of the 2 boxes as a basic NVR Switch?
