Roger
Some trade suppliers such as Hills Panel Products (Sheffield, Oldham) offer what they call "pre-band(ed)" which is basically 15 or 18mm MFC (melamine-faced chipboard, the trade term) in strips 6/9/12/18/24in wide x 8 feet long (convert to metric as 150/225/300/450/600 mm) in a range of colours. When buying MFC ask for one of the better quality boards such as Egger, Hornitex, Sonae, Caber(decor), Finsa or Kronospan and get a matching edging tape from the board supplier (even B&Q stock it) - not all tapes are a good colour/texture match (BTW, Egger MFC is probably the best of the bunch IMO) - Conti is cr.... not the best quality :lol: . Like a lot of people in the trade I buy-in "jumbo" sheets (2.6 x 2.0 metres!) when I need MFC and edge band it in house - not too keen on doing jobs for people turning up at the door as it can be a royal PIA either setting up for someone elses tape or banding poorer quality materials - if it goes wrong I get the blame, see
. The tool to use for trimming edging it is a Stanley window scraper - one of the cheapo yellow ones - just make sure that you point the blade inwards to the material at an angle.
The only way to guarantee a good chip free edge is to use a panel saw with a scoring blade :? , but failing that rough slightly oversize (2 or 3mm) and use a router with a NEW carbide cutter to finish off. Even then you may still get a few chips - so the worst side goes to the inside/bottom/non-visible side :wink:. If you have one, a disposable tip cutter is the absolute best for this and is what the kitchen boys use for jointing worktops.
*** I've just checked - there's an Arnold Laver in Kidderminster - good trade supplier but sells to DIY
Scrit
- who's now scurrying off to his bunker before getting lynched for giving away trade secrets!
