Meddings Pacera Pillar Drill
RosscoPCole
20 Oct 2022
Dorset
In the workshop I have a Meddings Pacera Pillar Drill. The nuts are missing from the depth stop and I was wondering what size are needed?
I have included a photo of the serial plate if it helps.
Thanks in advance.
It doesn't.
Have you looked for a manual for the machine?
http://vintagemachinery.org/pubs/detail.aspx?id=27829
Part number is 27, on page 2 of the manual. 1/2" BSF.
Proper knurled nuts in that obsolete thread will be next to impossible to source. Standard 1/2" BSF nuts are easy to source.
If you want knurled nuts, buy two of these:
https://www.gwr-fasteners.co.uk/m10-knurled-thumb-nuts-thin-type-din-467---brass-101563-p.asp
an 11.2mm drill bit (in brass an 11mm drill bit would be OK) and a 1/2" BSF taper tap.
It doesn't.
Thank you ChaiLatte. Much appreciated. I tried looking for the manual, but my searching skills aren't as good as yours.
