Rhyolith
I really like this little drill well built, easy to handle and high rpm. Its great for power brushing fiddly things.
Wolf Light Production Drill by Rhyolith, on Flickr
Unfortunately the switch started to play up, it always took a few seconds after pressing the trigger before it would actually come on. I took the switch apart to clean it and now it does not work at all.
Switch by Rhyolith, on Flickr
Further Investigation reveals its the sliders inside the switch not sliding enough (push them both into engaged positions and it worked).
You can seed how it works here, they just don't go far enough to let the current through.
All the various parts
What I can't figure out is why they aren't moving enough, nothing seems particularly (or evenly slightly) worn or loose... I was thinking maybe it needs some form of lube?
