spanner48
Has anyone tried connecting up 12 volt solar PV panels recently? There is [meant to be] an international standard - MC4 - which specifies the exact dimensions for the connectors. They are all "Dog-puppy" couplings, with Male-inside Female-inside Male and Female-inside Male-inside Female configurations. Each polarity uses the opposite sequence; so, once you start correctly, it's impossible to mix them up.
Except it's NOT a standard. We've been working with connectors from three different [Chinese] manufacturers. Systematically, the connectors of one either physically cannot [or can, only with great difficulty, or modification] lock in with another. And in more than one case there are moulding errors which make ANY locking-in impossible. Disconnecting is even worse; in most cases, once the connectors are clicked into place, it is impossible to disconnect, without physically pulling the wires out.
A simple job - connecting up three panels in parallel - which should have taken less than an hour, has taken 5 hours so far, and is still not complete.
Has anyone else met the same problems?
Does anyone know of a source of non-Chinese connectors?
