Quantcast
Matt filler
marcros
11 Feb 2011
Leeds
I have a piece of salted beech with a small gap that needs filling. It already has finish on, but this can be removed by sanding and reapplied, or touched up if necessary.
The hole is in endgrain, where the wood was a bit punky. It is on the edge of a spalting line, do a dark brown or black would be best.
The finish is flat and matt. Is there anything that I can use as filler that won't shine when light hits it. The end grain is polished to 400 or 600 grit if that makes a difference.
I need the smallest amount of filler- 1/4 of the size of a paracetamol tablet would be plenty. Bonus points for anything that I may have around the house!
ColeyS1
2 Nov 2009
Um um um, sounds interesting! Any pictures?
Sent from my SM-G960F using Tapatalk
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
cornflour and tea spoon v string coffee mixed to a pste
marcros
11 Feb 2011
Leeds
I will take one tomorrow. It is the top of a pepper grinder, so prob less interesting than you think.
CHJ
31 Dec 2004
Cotswolds UK
Mix instant or finely ground coffee to paste with medium or thick CA and apply with spatula.
(don't try to use Thin CA it will set instantly)
marcros
11 Feb 2011
Leeds
I had assumed that the ca would be gloss. may be simpler than I realised.
CHJ
31 Dec 2004
Cotswolds UK
Are you not going to have to blend sand it? if so stop at appropriate grit before it polishes.
marcros
11 Feb 2011
Leeds
yes, I will have to do that, I just had not considered it that way.
