Marples M148 doweling jig rods
feanorelf
15 Mar 2007
Milan, Italy
Hallo... I happened to reach this site, being one of the few results googling for Marples M148.
I have bought one a couple of years ago, and loved it from the first dowel. But now, for the first time, the 6" rods are not long enough for the work I am going to do.
I planned to buy a couple of 1cm rods, but now I am afraid that maybe the rods should be 3/16" (my caliper is a very cheap and worn thing... I should get a new and better one :oops: ). Can anyone owing the same jig confirm me the rods diameter (if 3/16", in a very delicate way, because it would be a big problem for me to find that diameter here in Italy)?
Thank you,
Luciano
Saluto di benvenuto al forum, Luciano!
First of all I think you mean 10mm or 3/8", as 3/16 is about 5mm or so. As Marples are an old English company, and the dowelling jig has been around a long time, I would very much expect them to be 3/8", Imperial, rather than metric. However, unless the castings are hardened (and I don't think they are - isn't this the jig with hardened bushes for the drill bit?) then I think you could get rid of the 3/8" rods altogether and drill out for 10mm. The difference is less than 0.5mm, I think.
Worth a try if you are stuck.
Ciao
Steve
You think right.
And yes... I believe drilling it out would be my egg of columbus.
Thanks!
:) I take it that is a literal translation of something Italian, is it? Uovo di Colombo? It's certainly amusing, I must remember it! Brightened my evening up :)
Glad to have you aboard.
S
Actually I believed it international, here it is quite common: it is said that Columbus during a dinner challenged several spanish nobles make an egg stand on its end and no one succeeded. Then he broke a bit the shell, and the egg stood. The others complained that this way it was simple, and he replied that it is true: it is very simple... when you know how to do it.
