Makita DHP481 loses its head
RossJarvis
20 Aug 2013
Petersfield, Hampshire
Hmm
After drilling only 40 odd inch and a half holes through 6 inch thick oak with an auger bit, I managed to shear the chuck holding screw off of my new Makita drill :cry: . Thinking I may be at fault I checked the spec and it says it can drill wood up to 76mm. When removing the bit with my torque wrench, it seemed to give at about 200Nm.
Was I being too adventurous or should I invoice Makita for the cost of extracting the screw :wink: ?
Woodchips2":2e4ie123 said:
Take it back to the retailer and ask for your money back then go out and buy a decent drill. :wink:
Regards Keith
...and who makes decent drills :?...none seem to like being dropped 30 foot or being dropped down a drain :x
They begin with H and are red in colour :D
If that's the Liechtensteinian company I think you mean, I don't think my battery configuration scheme would easily accommodate, nor might my pocket having recently purchased a red circular saw beginning with M!!
Since it takes 200Nm to be removed, you might not use the drill correctly.
I mean drilling is push and pull right? You push for few second and then pull up to prevent drill bit stuck/jam into hardwood/metal then start another round.
I am planning to buy this one for £110, new, metallic version. Your title give me a little concern but your content explains it, so I will go for it.
There is a very strong possibility I was not clearing the bit enough :oops: Thoroughly recommend the drill, a bit of a beast in all materials (hammer)
Well, then I will be happy to make the order. I am currently not in the situation of any drill-related work but I would love to get it as my gear to pair with my DTD148 at ebay
/itm/-/221905235756?
I am selling stuff like this as a collector :D so I learned a lot about drill/impact driver. That is why I hope it is your fault that crush the drill head :p and I mean it the good way around :D
