JustBen
I'm not sure which section this should go in.
Woodturning, hand tools or metalworking.
I've been given some steel bars of which I believe to be stainless.
Some at 10mm, 15mm and 25mm
They are all heavy, not rusty and very very mildly magnetic.
They are tough to grind, drill and saw.
So....
Could they be used as tools.
Google has confused me with this question.
It says SS has a higher carbon level than HSS so does that mean its harder and better?
One of the smaller bars has been drilled, tapped and has a cutting tip fitted on the end.
Could the 15mm bar be shaped and used as a skew?
I have seen round skews before.
Thoughts?
So....
Thoughts?
