Charlie Woody
I am making an oak TV cabinet which my good lady wants to look substantial. So after much discussion she said the top should be 45mm thick. However when I showed her the dimensioned timber she said it weighed too much (...... I had pointed this out originally ) She still wants the edges to be thick, so I have suggested the outside edges should be 65mm wide x 45mm thick with the centre boards 18mm thick.
My original plan was to breadboard the ends which would have been simple enough with the same thickness material. However I am now wondering how I should do it using the different thicknesses; do I (a) create a 6mm tongue 6mm down from the top edge of both thicknesses, which will be 6mm from the bottom of the thinner pieces and 27mm from the bottom of the thicker pieces; or (b) do I need to centre the tongue on the thicker pieces?
As usual your considered advice would be much appreciated.
