Dissolve
Hello,
I have my main workbench alongside a wall in my home workshop, It would be very useful to make a rasied workboard (two sheets of 18mm MDF for instance with spacer blocks in between to allow clamping all round smaller work pieces.
I have tried doing a "dry run" using off cuts of 18mm MDF stacked up and spaced evenly apart in a 3x3 "grid" of sppacer blocks, but with clamps on each block the top remains somewhat unflat. Would using a hardwood frame in between the MDF sheets be a more accurate way of retaining the boards flattness?
I could obviously plane these accurately and glue them together with simple butt joints before clamping the two boards together?
Any ideas?
Any ideas?
