sue denim":2cmy3205 said:
These are all good links , thanks.
A question or two
The switch is a two stage thingy and you can here the second switch kick in after the initial push button start. Will these cope with that requirement ?.
I like the reversible switch but I am concerned that the threading on the lathe will allow the work piece to be turned off the machine!.
Sorry to be a pain but I know zero about machine electrics.
Regards Sue
i believe the 2 stage bit is a safety feature, to either a) stop an accidental and immediate 'on' or b) deliver the electric to the motor in two stages so as not to overload the supply.
I think i read somewhere that it was MEM switchgear on myford lathes? if so is there a part number on yours? MEM eaton are still a going concern see here...
http://www.eaton.com/EatonCom/ProductsS ... d=EatonCom
and could be worth a call or email asking what the modern equivalent would be.
they have a product info guide here...
http://www.eaton.com/ecm/idcplg?IdcServ ... dID=203651
at a guess i would say you would need something like this...
http://www.tlc-direct.co.uk/Products/MM28ADS1X.html
i must stress i am not a qualified electrician or machine engineer, maybe you could print out the specs and ask your local sparks if its the right type of thing.
or if anyone else on the forum knows better, please correct me, i wont take any offence
