paulm
IG paulm_outdoors
In my workshop there is a double light switch, one side works the workshop lights and the other side switches power to an outside security light.
The security light doesn't seem to be getting any power when tested with one of the light up power detector pens, but the inside lights work and the cables in and out of the switch only light the pen up when the inside lights are on.
I think this means the switch is wired up wrong but not certain ?
On the right of the picture is the side that works the workshop lights and the left as you look at the picture is the security light side.
I'm also perplexed that the cable on the left has no neutral wire connected and has been snipped off which seems odd to me !
I remember replacing the security light a couple of years ago and I'm sure it was working at that time, so maybe the switch wiring is okay and the security light has just blown (I've changed the bulb and that hasn't helped) ?
Would have assumed it's the light itself except I'm just a bit puzzled that there seems to be no live indication at any time with any of the switch combinations which is throwing me a bit :?
I did have the soffits and fascias replaced recently on the outside of the workshop so I guess it's possible the wiring to the light has been disturbed as it runs in that space.
As a process of elimination it would be great if someone knowledgable on these things could confirm if the switch wiring is correct at least, in which case I guess I'll try a new light fitting next ?
Cheers, Paul
Cheers, Paul
