Lean-to side wall
caretaker
14 Jan 2007
Dounut city
On one side wall I will only need glass at the top half, as it will look out on a brick wall, on the bottom section I would like to put wood, but what would look nice but not to expensive.
Any idea's on this?
The size is 2feet high by 8feet long.
It might be just me, but I can't visualise the question you are asking - so can't offer any help.
Can you provide some more details?
Adam
Adam, I am doing a conservatory/lean-to, and one side faces a brick wall, about 8inches gap with drain pipes between.
I may have to have access to the pipes as well.
As this wall will house 8 pains of glass (4up 4 down) I think it would be better to put ply wood in the bottom panels instead of glass, but will it have to be special ply or is there a block board.
It will be sheltered from the weather a bit.
The glass pains run at £18 each so wood may be a cheap alternative.
Just got to convince the wife now.
