Lathe advice required
YorkieT
20 Jan 2008
South West Scotland
Hi,
Due to separating from my wife and having to down size the workshop to a small shed I am looking for a small variable speed lathe. I had a variable speed Union graduate which I had to leave behind but mainly turned pens and other small items.
The 2 lathes I have short listed so far are a Axminster AT1416vs and a Jet JWL 1221vs but would love to hear about any others I should consider, the lathe will need to be stand mounted.
Cheers in advance
Sorry to hear about that Yorkie, always a traumatic experience.
I got back into turning a few years ago and bought the little Jet 1014 single speed which is a nice little machine and have kept it since buying the Axi 1416vs which I've had for a couple of years. I turn mainly pens and other small stuff but it's good quality and does everything I want it to do.
Bob
Looking at the specifications the 2 points that the Jet outscores the Axi is on weight & bed length. Unless you know that you need that extra length, which can be handy for drilling, then the 1416VS has a larger swing, movable controls & a 1" toolpost stem.
Both brands have a good reputation.
As the owner of an AT1628vs, I may be slightly biased, but the AT1416vs is the slightly better machine IMHO.
Thanks for the good wishes and advice both on here and via pm's guys, much appreciated.
I think I will go for the axi 1416vs, just need to sort the shed out now :shock:
I bought a 1416 in July last year and have been really pleased with it.
Not sure how close you are to an Axy store but I called in to my nearest one just to have a closer look and a play and was offered the demonstration machine at 10% off but with a full warranty. I cheekily asked if they would give me 10% off a new base and they agreed! Might be worth asking if there are any ex- demos available?
I haven't checked but think I read somewhere when I was buying mine that the Axi machine has an induction motor while the Jet doesn't.
Hi Yorkie, sorry about the reasons why you’re doing this.
I have an AT1416vs - it’s a great lathe, liked it so much I bought a 1628. My daughter begged me to keep the 1416, tried it a couple of times and lost interest. If you’re interested in a little used 2nd hand one then PM me. Otherwise I’ll get it on the for sale pages.
Sent from my iPad using Tapatalk Pro
Hi dp. Did you sell the 1416? Looking for a lathe to get into turning and the 1416 comes highly recommended. Thanks
PM sent.
