I have just acquired the kreg Rocket Jig Kit from APTC. I followed the instructions as states but things are not right.
I'm using set-up no.2, using the 25mm screws and having the stop at 84mm. The problem being is that the screw head does not finish below the surface. On my first use, i had to file the screw head back flush to the face of the plywood. I have tried on MDF, Ply, solid timber but the screw heads are all sitting above the surface.
Is this a common thing or not??
