Kity 635 renovation help.
TPK
16 Sep 2018
Winchester
Could anyone help please regarding the feed roller drive belt on this machine, which I have to replace. The manual shows this as being 710 x 6mm but the only ones I can find are either 700 or 720. Is it best to go bigger or smaller?
One other point on the feed rollers. Everything I have seen suggests that there should be two pulleys on end of cutter block so that feed speed can be changed depending on type/size of timber; however mine only has the one position. Was this standard on the 635 or has someone altered it at some stage during its life?
Terry
