lastminute
..can anyone point out what might be the problem?
Thanks...Gerry
Thanks...Gerry
lastminute":1yg7ghxy said:Hi 9F....sorry for delay..the blade slows when I push the wood (2" pine...20mm mdf) through with just a medium force...its ok if I take it slowly!
The motor belt tension seems ok. as is the blade
The blade slows during the cut, then builds up speed after finishing!
...strange!?
Gerry
dickm":1kbdebrs said:Have you checked that it is actually the motor slowing down and not just the blade?
I'm ashamed to admit to having exactly that problem with my Elu Flipover, and started dismembering the electrics, screaming "HELP" to Bob Ninefingers and all the other things you do, before noticing that the central bolt was not absolutely tight![]()
. So although the motor was quietly spinning at normal speed, the blade was slowing down/speeding up exactly as you say.
Register today and take advantage of membership benefits.
