Hi All,
I've been lurking around the forum for about a year now but so far have always found the answers that I wanted without posting!
I'm creating a kitchen for my house and my GF and I have decided to go for Euro style cabinets with flat, handpainted doors with a draw pull mould at the top. So far so good- I have created this wth MDF in the past and will do so for this project.
The thing I need help with is that we have decided to create a section of full height cupboards with the doors in American Black Walnut as an accent in the room. I had in mind the use of bookmatched solid timber with the grain running straight from floor to ceiling with cuts where required for doors or drawers etc. The draw pull mould could then be easily routed into the top. My concern is that without a frame around the doors, they will be more likely to cup or twist. Should I be looking at
a) creating a frame around the door but using a raised panel such that the front of the door is flat or
b) using a veneered MDF panel for stability.
The problem with option a is that the grain will then not run continuously through the full height of the cupboards, the problem with b is that i can't route the draw pull in the top.
Any views or comments would be appreciated- if I'm going to the effort and expense of making this from matched timber, I want it to go right first time!
Thanks in advance
Seb
Thanks in advance
Seb
