Joints for boxes
dovetail2007
3 Apr 2007
Hainault, Essex
Guys,
I'm laid up for a week or so following an operation today, so I see it a good time to get together a list of projects to start when I'm back in the 'shop.
Top of my list is a baby walker, next is a range of boxes.
I've made boxes before, with little success - using softwood and mitres, cut on my CMS. These were in turn glued with Titebond in a pictureframe clamp. Needless to say, getting a tight fit was challenging.
I'd like to make some boxes, maybe 150x100x75 ish, or maybe bigger it that is easier!
This week's messing about with the router table produced a box joint jig of sorts - not very reliable nor safe, but it can be worked on.
I'd love to get a DT jig, most likely the cheap APTC type - c.£30 and getting a small 1/4" router to use in this (Trend T3 or similar) as my B&Q 1/2" is a bit too heavy handed for handheld work and is mounted in the table at the moment.
So, my question:
Which joint would you use? Mitre, Dovetail (with jig+new router) or comb/finger/box joint? Or is there something easier (other than butt joints, please ;) )
Also, for the bases I have just routed a 4mm groove along the bottom, and inserted the hardboard - this worked well, but for lids, I'm stumped. I don't have access to a bandsaw so cannot cut the top from the bottom afterwards.
Oh dear, another long and waffling post :oops:
Cheers,
Sam
I like Houndstooth DTs for jewelery boxes and large finger joints (they don't look like B&Q specials then) for more mundane boxes. For the finger joint approach, i prefer only 3, 4 or 5 fingers forming the joint
Another favorite is a mitre with splines ot re-enforce the joint. You can make all manner of attractive joints with this technique
Aye, I have seen those already Smudger.
My poor efforts of jig making were along those lines, albeit a more basic version.
I think my priciple was right, but following through was more difficult :p
Is there any way houndstooth DTs can be cut on a router?
Also, for splined mitre joints, do the slots for the splines have to be cut using a TS?
You could try the drawer lock type joints. All you need is the special router bits.
You don't need a special cutter at all. It can be made with a groover and a straight bit, or even two straight bits:
Strong and relatively forgiving of minor discrepancies.
Scrit
Thanks for all the replies.
I am still deciding which option to go with.
I am not going to go with Houndstooth DTs as at the moment I do not have the skill to cut these successfully.
Drawer joints and splined mitres may be do-able however without a TS I see it impossible to cut the splines.
Cheers, and keep the sugestions coming :)
Sam
I've cut some before with a rather blunt tenon saw so I can't see why not :) give it a go on some scrap and see how you go!
No, no, no, no, no, no, no
And I forgot to say no!!!!! :wink:
Just practice a bit and you'll find they are really quite easy
Use a router table and bit with a knock-up jig to hold the box - I do
