Hello guys ,
I'm in the middle of an exhausting process : flattening my jointer plane (Stanley n°7 plane) ...
But . . . wait a second, before I die for the fatigue : How far should I go ?
This is my set-up :
I've a marble strip, 4 feet long, that I use with sandpaper attached for flattening.
I've checked the marble strip with my straight edge and there is no light passing in between the marble and straight edge, so I'm assuming that my trueing/lapping surface Isn't that bad
The Straight edge is a Veritas one, a 36" long and ground flat over the entire length
to within 0.0015"/0,03 mm (Sorry I'm Italian we use metric system).
I've also a feeler gauge, its smallest blade is 0,0019"/0,05mm thick,
for the purpose of this measurement I've managed to find something that is thinner than the feeler gauge blade ... I've a Borletti digital venier caliper and I've used it to measure first the smaller feeler gauge blade, when I got the 0,05 reading I kept measuring various materials untill I found
some plastic/paper sheet that was thinner than the feeler gauge blade and I've found something around 0,0007"/0.02mm and 0,0011"/0,03mm . . .
When things get smaller it's difficult to get reliable/reproducible measurements but I would say
that I defenetly found two "blades" that where increasingly smaller than the blade of the feeler gauge.
With this tools I started measuring deviation along the sole of my jointer !!!
This is my set-up :
