Steve Maskery
For years I've used drum sander in a drill press, and the Carroll ones are very good. Well-made and, best of all, you can use ordinary abrasive paper. However, they do not oscillate, and this makes a big difference. I saw the Jet on offer in my local toolshop and decided to buy.
It's great. Good capacity, pretty easy drum change. Quiet, if not the smoothest machine, it rumbles a bit. Good switch, decent dust-extraction. Table size is adequate for most jobs but anything long needs extra support. The table is easily adjusted for square, and being cast iron, is nice and easy to work on.
It's quite heavy, a struggle to move about on one's own. It needs a base. It's too small to stand on the floor and too tall to be used on a bench.
I'm glad I bought it. It would be better if, like the Carrolls, you could use ordinary sandpaper rather than having to buy the drums. I would like to see a bigger drum available, say 80mm, for long slow curves such as chair backs. But on the whole, it is very good.
