Hi All,
Seasonal greetings.
Had a chance to examine my Dad's old Craftsman drill press. I've had it years and it's always had a problem with drills not being centered.
So Father Christmas brought me a magnetic base and dial gauge so I've been measuring a few things.
The only number I can find on the drill press is 101.03581 and I can find a reference for it.
I found this website for craftsman spares but the diagrams for anything that looked similar were not good.
http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Drill-Parts#targetAction
I've measured the taper and it has 0.05mm runout. The exterior of the chuck has 0.12mm runout and a drill (Dormer 9.5mm) in the chuck has 0.19mm runout near the jaws. Obvious with a 2mm drill this is way out.
I've mic'ed up the taper as well as I can with the quill in the machine and it seems to be a JT33 but I'm not experienced enough with a micrometer to be sure. I can read a mic easily but it's getting the tool square on that's the issue.
I mainly do woodwork and some metalwork have found that the existing run-out to be and issue. eg when making plugs for counter bores, at nearly 0.2mm run out you get 0.4mm error between the pairs and it forms a ring.
Preamble over: it come to two questions
1) Would I be right in assuming that the chuck needs replacing or are there some other hidden issue that may cause the run out?
2)Where can I get a Jacob's replacement in the UK or are there some 3rd party products that are worth buying?
I've found this https://www.cromwell.co.uk/index.php?q=0&p=viewproduct&i=KEN4401450K&message=addtobasket but I'm not sure of the quality.
Many thanks
Andy
Edit: It does not have a removable mandrill, least ways there's no slot to allow a taper removing drift so it seems I'm stuck with the taper.
Seasonal greetings.
Many thanks
Andy
