graduate_owner
I have a number of questions regarding single to 3 phase converting, and I'm hoping someone on the forum may be able to help.
First -I have a 3 hp static converter which works OK but I know these are not ideal. I also have a spare 3 HP 3 phase motor and my question is, can I connect the motor to the converter and will this effectively make it a rotary converter? If so, should the spare motor be connected star or delta? My instincts tell me star, and it suggests star in the book I have. ( be prepared for disappointment if you use delta, it says). BUT I also have a rotary converter (trying to repair it) and the motor on that is connected delta, and the instructions say it should be delta. So I am a bit confused.
Second - I use an inverter to give me variable speed on my lathe etc. Using motors connected in delta, 240volt. I tried connecting it to a 3 phase 1 HP Canning polisher (rated 380 - 415 volt) and expected a loss of power and torque. What happened though was the speed increased from zero as I turned the speed control pot on this inverter, then reduced down to zero as I continued turning the pot. The reading on the inverter display also went from zero up to about half way then back to zero. That has never happened on any other motor. Does anyone have any ideas? I assume the Canning motor is an induction motor but I don't know.
K
K
