Is American Black Walnut food safe?
LyNx
27 Jul 2005
swindon
A friend needs a chopping board and wants it in walnut.
Is ABW ok to use?
Andy
Hi Andy
I dont think it is but if I am wrong I am sure someone WILL ( :) ) let you and me know
There are some nice chopping boards here made with ABW. I know nothing about food safety but if others are making chopping chopping boards out of ABW, I'd take the risk.
Gill
Certain species of juglans nigra produce a toxin called juglone, which is poisonous to plant life around the tree as it is growing, and I know that stables using wood shavings for horse bedding from sawmills etc won't use them if they have walnut in them. I'd keep the walnut for kitchen joinery & use beech for the chopping board if I were you.
RP
I don't know about safe, but dark woods tend to taint the food with either their colour and/or their flavour (sand some walnut and see what colour it makes cheese go). I suppose that's why cutting boards are all traditionally light fine-grain timbers: sycamore, beech, maple, olive, apple, etc. I reckon any chopping board with dark/tropical woods in it is just for show.
Scrit
Personally I think that these issues can be taken rather too far, you can eat the nuts, and probably wouldn't want to eat the timber anyway (unless you're really hungry :shock: )
I suspect that Scrit has the real answer, i.e. in terms of colour tainting.
Apparently apple juice contains a known carcinogen, but that certainly doesn't stop us from drinking it, farmed fish is well known for its levels of PCBs, Dioxins and flame retardants and we still eat that. Why worry about a chopping board that you are unlikely to eat anyway.
Cheers,
Dod
P.S. - I do appreciate that if you're making it for somebody else you would probably want to play safe
Apple seeds are actually very good sources of cyanide :shock:
Given that as WD says you can eat the nuts and walnut oil is used for salad dressing, I'd bet on it being okay - but don't know if abw is the source of edible nuts and oil.
Does ABW mark badly like oak when in contact with iron?
Tim
Further fuel to the fire, reproduced without permission from FWW July/August 2005 (knew I'd read about it recently):
"Although walnut is a joy to work, its toxicity can do damage.
The tissues in mature walnut trees contain the chemical compound
juglone as well as other extracts that can irritate the eyes and skin.
Precautions are reasonably simple: Wear goggles and a dust mask
or respirator when machining black walnut, and wash exposed
skin with soap and water afterward. Those with greater sensitivity
might want to wear a head covering, face mask, long sleeves,
and gloves. Juglone also can wilt or kill plants, and harm horses
and dogs, something to consider when disposing of sawdust or
if your dog likes to chew on table legs."
RP :shock:
If you've ever picked or halved walnuts you will find that the juice from the husks and in the shells will cause the hands to go brown. The bark from walnut trees was once used in vegetable tanning and the husks for commercial dying, so I suspect that there must be quite a lot of tannin in the timber, too.
Scrit
Scrit":3qtx4q1z said:
If you've ever picked or halved walnuts you will find that the juice from the husks and in the shells will cause the hands to go brown. Scrit
Walnuts used to be used for making Vandyke brown. You can even use a walnut kernel to hide scratches in brown furniture by rubbing it over the scratch (not the antique restorer's method mind :) ).
LyNx":3hwn2ql9 said:
thanks for the info people. Best if i stick to beech or maple :?
or sycamore - probably the only one which will be native.....
Scrit
mudman":1xcdo5y6 said:
British-Trees.com has beech as native.
Yes, but if you go to a timber yard there is a high probability that the timber you will be offered will be German, especially if it's steamed beech :lol: . Similarly commercial maple is normally from North America as the quality of home grown is very variable.
Scrit
