Is All MDF Created Equal?
Marineboy
11 Mar 2016
Northumberland
I plan to board the lower half of my hallway with 6mm MDF, which I will rout with V grooves 100mm apart, in order to create the impression of T&G boards. I will paint with white eggshell.
I bought a small MDF board from B&Q to set up my router and make a jig to ensure repeatability of the groove spacing. After routing the grooves I see that the cuts are very 'wooly'. Even when sanded the finish leaves something to be desired.
Of course, I understand that MDF is made of fibres - however, I don't recall other MDF I have used to be quite so wooly. Are there different grades/qualities of MDF, and would I be better getting the sheets I need from a proper timber supplier or builders' merchants?
I've found the standard (ie not MRMDF) to be a bit wooly as you say. I use MRMDF for pretty much everything and the finish is better. Last lot I bought was Medite which I understand is about as good as it gets.
They are definitely not all the same!
Buy MRMDF (Moisture-resistant MDF). It's not much more expensive but nowhere near as woolly.
Did you know that you can buy MRMDF already machined to get that T&G appearance? Ask at your timberyard.
S
You can get sheets already grooved for T&G appearance, I think it is water resistant as well
Not to long ago I finished off a hallway for a client, they had already purchased the sheets of T&G MRMDF, i hadn't encountered it before but found out it's readily available.
I really wouldn't be looking to grove it my self, it would take way to long to get perfect.
You can get it pre primed as well which makes painting it a tad quicker
Personally I'd go for either 9 or 12mm mdf. If you put a v groove in 6mm mdf there won't be much left.
Not all MR MDF is created equal. I've tried some that was claimed to be moisture resistant but was too woolly to use for my purposes. I can't remember the brand. Medite seems good.
Thanks for all the replies. MRMDF seems the way to go, I still fancy doing the grooving myself, have done the test piece with my Festool router and track and it has worked out well and not too time consuming.
B&Q now use medite ( standard not MRMDF ). Comparing prices including VAT it is the same price as some timber merchants, £21.50 for an 18x1200x2400 sheet. B&Q also seem to store it better indoors for MDF and give 10 free cuts.
Hmm. There's a Medite MDF and a Medite MRMDF?
Sorry. Just looked. Answer is yes.
https://mdfosb.com/en/medite/products
That is interesting, as it's a metric size. A trad 8x4 sheet is 2440 x 1220.
GeordieStew - yes.
Just looked at the label on my bit of MDF from B&Q and it doesn't mention Medite as the maker - wonder if it is stacked separately in the warehouse?
Sorry the small size was my mistake. I took these photos 141017 in B&Q Trafford Park, opposite the panel saw.
    96.6 KB
    190.9 KB
    103.5 KB
I often see the statement that MRMDF doesn't cost much extra but last time I considered buying some, it was considerably more expensive than standard MDF and I see that Ridgeons are currently quoting £41.59 for 18mm MRMDF and £32.92 for their premier grade 18mm standard MDF.
Travis Perkins are quoting £20.80 and £37.57 respectively, plus VAT, including a discount, for Caber, not Medite.
Comparing to the £22-ish for standard MDF from the bigger stores, there's a massive difference for MRMDF.
So, do these figures converge greatly with trade discounts or am I going to the wrong places?
I would normally only want to buy two or three sheets and delivery would need to be factored in if I wasn't buying locally.
Buying advice welcome!
Duncan
Duncan
I've recently been using some 18mm MRMDF from Wickes.
It doesn't have a brand name stamped on the board but it seems to be a decent product in my opinion.
I bought half a dozen of them and at the time, and if you bought 3 off they were on offer for £23 ish each.
It's the first time i've used MRMDF but I noticed router profiled edges do seem cleaner and less fluffy than with standard MDF.
