Blister
Hello
Does anyone know if and how you can upload photos from a Ipad onto a forum ?
I didn't say you couldn't. I said you couldn't do it directly to a forum. And that is true.Mr Ed":1k893vi0 said:I don't know where everyone gets the idea you can't upload photos from an iPad - absolute nonsense.
I do it all the time;
I use an apple camera connection kit that is a little white plug which makes the apple connector on the bottom into a USB, into which I can connect my camera and phone using their respective cables. When you do this a little dialog box comes up that allows you to pick the images to download and delete off the camera if you want.
I then use an app called Snapseed to edit and refine pictures, from which I can directly upload to Flickr when I'm done. Alternatively you can email upload to Flickr as well if you want to do it without using snapseed.
I then go to Flickr to grab the html code (exactly as I would have to if on the PC) and use it on the forum.
To my mind that's no more complicated than using a macbook or a PC.
Ed
Actually I was more referring to Nev's comment that uploading a picture should be a basic function of the iPad, which it is.Eric The Viking":curnr450 said:I didn't say you couldn't. I said you couldn't do it directly to a forum. And that is true.
Eric The Viking":hi75tzd9 said:I too have the camera kit. It's a chocolate teapot for me, as I can't plug in Compact Flash cards (as used by many pro cameras), nor connect a USB card reader, even though it has a USB port. You can't even write to a USB stick that way either.
E.
Register today and take advantage of membership benefits.
