Rob Platt":22h1mwpn said:
I would charge £150 and expect to do them in a day and would stay to finish.
Hope this helps.
All the best
Rob
p.s. Somebody would undercut me possibly, but I no longer care I always think it`s the clients loss if that happens.
Thats very reasonable pricing, I shouldn't expect too many to under cut that if any at all.
I would charge 28.50 per door.
method of working for me.
1) check, and double check door sizes to frames.
2) if all ok, take off all doors that are to be replaced and remove outside.
3) Unwrap all new doors and place next to respective frame
4) mark and cut every door into frame
5) put hinges into every frame
6) Then door by door, mark and cut and swing.
7) mark out every door for furniture.
8) cut apertures for every door
9) mark out latches
10)router each latch
11) run round fit latches and handles
12)then chop each latch plate in one by one.
13) check doors
14) job done
On average using this method and a track saw and a hand plane, i was fitting a door and ironmongery in 28 minutes.
But a single door would take me 55 minutes from tools out to tools away.
