Hi ,
I am going to make some built in cupboards, built around a chimney breast and spanning the length of the wall. The best way to explain it is sort of three cupboards all joined together, one cupboard spanning the width of the chimney breast and then a cupboard each side of the chimney breast. If you know what i mean.
Both the cupboard spanning the width of the chimney breast and one of the other cupboards, are going to have just shelving for storage. The third cupboard is going to be have a hanging rail, and a couple of shelves above the hanging rail.
After looking in a couple of woodworking books and on the internet, i thought i would make the cupboards out of 2by2" framework, and then use a oak veneered mdf for the end panels and the shelving.
The side frames for the cupboards are to made up of two stiles and three side rails, the number of front and back rails will depend on how many shelves are in that particular cupboard. Use veneered mdf on the two end frames and leave the other side frames open as it were. Then for the doors use floor to ceiling sliding doors.
Do you think this is a good idea or do you suggest a better way of making the cupboards :?:
Is 2by2" the right size timber to use. :?:
Would it be better to rebate the veneered mdf into the end frames or just screw one whole mdf panel to the end frames :?:
What joints would be best to make the cupboard framework :?:
Sorry for the long explanation, i hope you can understand it.
cheers
cheers
