MikeH
Hi all,
Looking for some design help if poss please. Possibly this post should be in the design forum but as that seems to get limited mileage I thought I am more likely to get an answer here.
I want to build some bookcases in my downstairs hall to better use an odd space. Problem is that I need to build them around a radiator.
Space is a bit like this (1st time posting a picture so hope it works OK!)
The magnolia colour is the walls, big gap on the right is a door. To the left of the door the white blob is the radiator I need to build around. I want the cabinet up the wall the radiator is on and also up the wall to the left of the radiator so it is an L shaped unit.
I want to maximize the space by going almost up to the ceiling. I don't mind the approach with a cabinet below extending to just above the radiator, that has advantages as I could build the unit in two pieces as my workshop is not that big. I was intending to effectively box in the radiator possibly using the pre manufactured MDF fronting you can get in most Sheds.
I am struggling with how to transition around the corner whilst maximizing the space. Was thinking of a possibly having a small hidden door on the angle which I could stash long things like umbrellas and brooms etc behind into the corner but that may be a bit much. Structurally the wall the radiator is on is block work but the wall to the left is plasterboard.
I will probably make the carcass out of faced MDF with hardwood lippings etc. Possibly make any doors out of solid wood, fielded or whatever.
My workshop is pretty well equipped with the main power (PT, Big and small BS, TS, Mortiser, Pillar Drill, Lathe etc) and hand tools (LN planes and chisels etc) so making the unit should not be a big issue even with my limited skills!
Any ideas or examples on how to tackle this would be most welcome.
Thanks in advance.
Thanks in advance.
