If you're spraying then you've some slightly more effective options open to you. Morrels clear Omnia is a water borne exterior finish that seems to buy you a few extra years of yellowing protection on pale timbers, if you keep your box away from direct sunlight that would translate into a material gain.
Another possibility is Holly, which seems to stay white for considerably longer than Maple or Sycamore. The difficulty is finding good quality white Holly. Up until ten years or so ago it was fairly easy to source, now it's anything but. I've been told that warmer winters are to blame, but I contacted people I know in Canada and the USA with a view to importing and I'm hearing the same story from them, bright white Holly is very thin on the ground.
Or there's two pack bleach, but that's such nasty stuff to use that it's impractical in most cases.
Finally there's a soap finish for open grained paler timbers like Ash. Labour intensive, low protection, and high maintenance. But you do get that bone white, matt finish that is so on trend at the moment.
It's interesting, since the late 1990's many designers and furniture makers have used a combination of steamed American Black Walnut with Maple in the US and steamed ABW with Sycamore in the UK. We're now seeing a lot of that work looking pretty dreary as sunlight has turned the steamed Walnut to a washed out muddy brown and the Maple/Sycamore has turned a nasty tangerine colour. Ho hum.
