Hello puzzle makers,
I have been experimenting with my new AWFS18 by making little Christmas card puzzles (95mm square cards glued onto 6mm 5-ply birch).
Using the original blade fitted as standard I have managed to cut a fair number of cards into 1 inch squares. These are quite easy to clean up by sanding all edges and trimming anything sticking out with scissors, one piece at a time. So far so good.
I then ventured into cutting large earlets. Still OK to clean each piece individually, but getting tricky.
Then I managed to cut 31 smaller more intricate random pieces, including a star figural that came out rather well. Apart from the fact than I completely chewed up the very last piece (the insert is not flush with the table so I couldn't move the piece freely, it kept getting stuck against the "kerb" :x ), I felt rather proud and optimistic for the future.
BUT, I can't clean up the puzzle. I made it up, put it face down on my desk, hold it together the best I could with my left hand and sanded the back with a sanding block and ordinary fine grade sandpaper. Got rid of the main splinters but it all remained very fuzzy.
I tried one piece at a time, same thing. The cut is too intricate to sand the edges. Or is it what you need to do, go over each piece with a toothpick wrapped up in the finest sand paper?
What am I doing wrong, or not doing?
I gather there are also 2 important parameters at play here:
1- The blade. I don't know how good the blade is for that job (it does cut and is certainly long lasting), but when it breaks I will replace it with a Flying Dutchman Superior Puzzle blade.
2- The wood. It wasn't cheap (almost £20 for a 8'x4' sheet from Harlow's), was said to come from Scandinavia (Norway was mentioned) and looks nice on the outside. However I have come across the occasional small void inside. It splinters easily when cutting and especially sanding, but I have nothing to compare it with apart from the maple that Turtleteaser uses in America for his wonderfully intricate jigsaws where each piece is perfectly formed, dense, smooth and definitely fuzz free.
I would welcome any comment or advice on this cleaning up issue. :idea:
