How do you turn a positive outline into a negative? UPDATED
Mcluma
2 Feb 2005
Pyrford - Woking
I have been cutting these hinges with the router following a template. These templates were made by me using the band saw, following a pencil line – the template is good, but not perfect – I am looking for something better
I spoke to Trend the manufacturer of the hinge jig but they do not have anything in there program to actually match a 16 degree corner – it can be done by using a 32mm cutter – well these are not available – so the best option is to have a template
Is there a way by actually using the hinge itself and a router to create from the hinge outline a template?
I can then use the guide bush to ride up against the template and make the hinge cut out.
Untitled by mcluma, on Flickr
Would this work?
Make a male template of the hinge leaf (only the curved part) by attaching the hinge to a piece of MDF follow closely the outline with a bandsaw and finish off with a bearing guided cutter. Attach this template to another piece of MDF and using a guide bush and cutter of your choice make a female template. The same guide bush and cutter could then be used to cut the rebate for the hinge.
Brian
Use the hinge and follow it with a guide bush, making a template which is over sized by the radius of your guide bush less the radius of you cutter. Now follow this template adjusting your guide bush and cutter to get the cutout you require.
~Nil carborundum illegitemi~
Personally I'd do just what you did previously. Just take more care, perhaps use a scratch awl to make the original marks and be prepared to finish, after band sawing, by hand. Make it a snug fit. Of course if the hinges vary in size then it's all a waste of time really.
xy
I use the same system as Deserter to make templates for hinges, although I take the hinge and measure the offset of the guide bush to my cutter and then cut a piece of scrap to this size. I then follow this around the hinge with a fine tipped pencil and cut out to the line. It is pretty accurate and only occasionally needs a little fettling for a perfect fit. HTH :wink:
You might like to try this method.
Secure your hinge to the template material and select a 16mm Guide with a 4mm cutter and rout the template shape.
Stage 2 With the shape produced select a 30mm Guide with a 10mm cutter to rout the shape where the hinge will fit neatly
Template Tom
Template Tom
thanks for the answer on this one,
I had a member on another forum creating me 3 templates by using a CNC
But its good to know that its actually that simple to create them myself by using different guide bushes and router bits.
So in short, but insing this set-up its possible to create a negative from a positive all the time?
The world is indeed a small place.
Remember the issue I had in turning a positive outline into a negative to make a jig to cut-out my hinges.
Well Tokyo Stu came to the rescue with his Icarver. Stu offered to cut the jigs and send them over to the UK.
The next evening I send him the drawings, and Stu went straight to work with them and had them in the post that evening.
They arrived yesterday and I have fitted them in my Trend hinge Jig. I have not tried them out, but all measurements look right, so there should not be any problems
Here is the drawing that I send to Stu
Here the Icarver at work
One done
Job completed
In the mail and arrived here in the UK – very well packed
Stu – a big thank you from me to take on this challenge
A short progress update on hanging the doors
As you all know I got some intercontinental support with this one
To cut the hinges I use a Trend hinge jig, this is a fixed bar with preset positions to cut-out the hinges. The same jig you use on the door as well on the door style. It makes light work of an otherwise tedious measuring job, especially if you are using three hinges on a door.
The hinge jig is more usable for square edged hinges, not the so much the one I use which have rounded corners. So a solution needed to be sought. Originally I made new jigs with the use of the band saw, but found these not 100% accurate. Just a tad to sloppy
Then Tokyo Stu came to the rescue. He cut me 3 jigs with the use of his Icarver and these are perfect – the turnaround between making contact with Stu and having them in my hand was exceptional.
This time I took the time to fit the new jig inserts properly into the jig. Yes it meant that I had to drill holes in a expensive jig, but if you have to cut 24 doors or 72 cuts on doors and another 72 cuts on door frames, you want something that is sturdy and fit for heavy production – (I have been saying to the wife that this refurb can’t any longer been seen as a DIY project)
DSC_3708 by mcluma, on Flickr
Sofar I have cut 7 doors with the new jig and I’m very happy with the accuracy of the cut – a nice tight fit
DSC_3711 by mcluma, on Flickr
Here a few more doors that have been done
DSC_3710 by mcluma, on Flickr
DSC_3718 by mcluma, on Flickr
DSC_3722 by mcluma, on Flickr
