builderchad
I am in the planning stages of making a frame saw and have recieved my blade and blade holders from Dieter Schmid (http://www.fine-tools.com/gestell.htm). The holders are 2.6mm thick so I need to cut a slot in the saw arms of about 2.8mm as I dont want them to move about too much.
My smallest router bit is 1/8" which is just too wide and wouldn't have the depth to go through the saw arm anyway. I can't cut the arms in half to make recesses as that would compromise the strength of the saw. Using a jewellers saw seems like a possibilty but I can see myself making a real mess of that :shock:. Besides I would need to start it with a 2.5mm wood drill bit and have not found any long enough as the thickness could end up being just under 2 inches. And I guess that a long bit at that length would wander a hell of a lot even on a drill press. Taking that thickness down is an option if I can't find a way of cutting this slot.
Are there any fairly simple methods for cutting thin slots (or through mortices I guess??)?
