I recently made some housing joints where I had over sized the tounged part by 1mm (- I actually got around the problem by sanding off the extra mm on the tongue but that seemed to be cheating a bit?)
But if this was not possible, how would you go about widening the housing?
I suppose using the router again is one solution but 1mm is very small?
What about a plane - do the Stanley Types 98 & 99 work in such a case?
What would you do?
Rod
What would you do?
Rod
