Horizontal kitchen waste overflow
andrewm
30 Oct 2003
Cambridge, UK
I have a kitchen sink that is probably about 10-years old. It is not dissimilar to the one sold by Screwfix here:
http://www.screwfix.com/prods/31398/Kit ... teel-Sink#
but has no brand on it so I don't know the manufacturer.
I need a new waste for it but what is unique is that the overflow is at the bottom of the draining board and held by a screw through the drain. It is therefore horizontal and not vertical like most.
None of the usual suspects stock a sink waste like it and new sinks like it seem to come with a waste included.
Does anyone here know a source? It would be a shame to have to scrap a perfectly good sink for the lack of a suitable waste.
Andrew
I'm not 100% sure of what you need but if you mean what I think you mean, try a caravan place (maybe on 't internet ) that supply fittings: maybe a tiny sink plug hole would do the trick.
It's not a plug hole. To try again with a better description:
The draining board, instead of draining into the sink has a rectangular overflow at its lowest point which should connect to the sink waste via a flexible pipe in the same way that a overflow to the side of the bowl would in a normal kitchen sink.
Andrew
Bad timing - I had one of these on a job i've been working on, but I threw the sink out earlier in the week.
Not sure where you'd buy one from - all the sinks I fit are supplied with the waste.
Karl
jasonB":ulb1zuww said:
This what you are looking for?
Jason
Yes, looks very much like it. I will print out some of the details and compare tomorrow.
Does the Blanco site actually sell spares? It seems to list them all but I can't find a shopping basket.
Andrew
