Homemade turning tools
Finial
3 May 2008
London
In case anyone is interested, I have put up a page on my web site with information about making your own turning tools, including gouges, bead forming tools, hollowing tools, centre finders, ball cutter and more. Also some information about metal turning on the wood lathe. Hope it will be helpful to someone. Comments welcome!
Terry
http://www.turnedwoodenbowls.com/forotherturners.html
Very interesting, Terry.
I`ve made a few turning tools myself, with varying degrees of success, although haven`t tried forging or heat treating. I`ve bookmarked the page for future reference.
One tool I have made is a thin parting tool from a machine hacksaw blade. This works well enough, with a single bevel. Can you explain the advantage of a double bevel as in your example?
I would try it if I thought it would improve the tool`s performance.
Ian
I have several skew chisels and odd scrapers made out of old engineering files which I ground the teeth off on a belt sander - The steel is already hardened and holds a remarkably good edge.
Obviously you mustnt over extend the tool rest by a long way though as the steel can be brittle.
Hmm. Good question Ian. I was really copying the shape of commercial parting tools. Most people probably push parting tools straight in, including me most of the time, so they are scrapers when used that way. The ultra narrow one on my page works well if pushed straight in. I use a 10mm wide one a lot, also as a scraper, and that has a single bevel and I use it bevel down. So presumably the narrow one would work with a single bevel too.
If you angle the tool upward, one with a single bevel underneath would have positive rake and might be more inclined to dig in.
The main reason in my mind was that having the edge low down on a flexible blade ought to reduce the chance of it twisting if presented at a tilt.
You could easily grind a very short second bevel on yours and see if there is a difference. I'd like to know the outcome.
stevebuk":1g83y1xy said:
hi
i'm interested in how you made the mice really, they look lovely..
Thanks, I think they're cute, but they don't fool our cat.
There is no secret method, just a straightforward bit of spindle turning, sand a flat on the bottom, drill holes for ears and tail, insert little leather discs for ears (cut with a homemade punch) and a bit of leather cord for a tail. The fiddly bits are the ears and getting them on the web page.
Hi Terry
Re bevels on a thin parting tool:
The first pic is the tool I made with an old machine hacksaw blade, with single bevel.
The second pic shows it after I added a smaller bevel on the bottom edge.
I`ve tried it briefly since regrinding and it does seem to cut a bit better, with a better cutting action rather than a scraping action.
I`ll need to experiment a bit further and perhaps tinker with the bevel to see if I can improve it further.
One advantage of making your own tools is that you can afford to experiment, and hopefully, learn about how tools behave using varoius angles and bevels etc, without ruining expensive commercially produced tools.
Ian
That is really interesting and I have bookmarked the tool making page Finial. Thank you!
I did a weekend course with Ian Wlikie, well worth it! And he recomended a thin parting tool from Axminster and to grind the secondary bevel on it. This I have and have the said bevel. It works a treat and the bevel provides the bevel for the cutting adge to sit on and control the depth of the cut.
This is the tool http://www.axminster.co.uk/crown-crown- ... prod29650/ and I just ground about a 1/4" bevel off of the point, after trying it as shown, and it really does work well. When I'm parting off something a few " diameter I make a double or so width cut so as not to let the blade bind on the wood. Works a treat, gets bloody hot and doesn't effect the cutting one little bit. To sharpen, just touch it, at the correct angle, on the grind stone. Job done!!
Ian, I'd be tempted to grind back the top bevel a bit more, you have a very obtuse bevel angle there, over 90 degrees.
John, how does yours compare to what Ian has done?
finial, would you have any suggestions on how to identify one steel from another to ascertain whether its suitable for tool making?
today i changed the drop links on my van and thought i might have a go at a small hollowing tool with the old ones. (round bar approx 10mm x 300mm once i've cut the ends off)
ta
nev
you could make a thin parting tool from an old crosscut saw.
use an angle grinder to cut to the rough shape and use the bench grinder to finish it up.
epoxy wooden handles on to each side (you would have trouble drilling steel that tough)
i like using springy steel because it wont snap if you get a bad catch
ta
nev
Not for certain, but if it is taking much strain in the van it could well be high carbon steel, for strength. Sorry to say I don't know what a drop link is!
One fairly good way to tell is to touch it on the grinder. If you get lots of sparks it is likely to be carbon steel. Compare it with a bit of mild steel such as a large nail (not a masonry nail) on the grinder and see the difference. That rod sounds good for a hollowing tool. Try heating and quenching the end to see if it will harden. Have fun and let us know how it goes.
You would have to be careful in the cutting and grinding not to overheat the steel, but saw blades are useful. There are drill bits that will go through a saw blade if you use a bench drill, or you can anneal the part you want to drill. But if epoxy holds securely that might be less trouble. Do you have to roughen the metal?
One problem with using a saw blade for this is that it will get very hot in use and that could easily draw the temper. But a thin parting tool cuts freely so it might well work even if blued. What did you find?
ta
nev
oh yes, plenty of sparks, took about 50 strokes of the hacksaw to saw the ends off (10-12mm)
the drop link is part of the suspension that joins the anti roll bar to the shock mounting, so takes a fair bit of punishment.
i shall venture back into the shed tomorrow and see if i can do anything with it! (hammer)
I read on a metalworking site someone's idea of cutting sections out of an old TCT saw blade for use as a parting tool. Perhaps the idea could be used in wood turning. A 10" blade could yield a number of useful TCT tipped sections ready for mounting in a handle. I have not tried this myself but it sounds plausible.
K
I'm not sure I'd bother with TCT for parting tools for woodturning. You really need a sharp edge to peel off the wood fibres at relatively slow speeds and TCT doesn't get anywhere near sharp enough IMHO even if you can diamond lap it.
TCT saw blade teeth are intended to go very fast and metalworking TCT tools are intended to be worked very hard (blue steel chips).
Hope this helps.
Jon
